2005 Accord LX Door Panel Replacement Front Passenger
Old Mar 26, 2013 | 11:14 AM
connam06's Avatar
Default 2005 Accord LX Door Panel Replacement Front Passenger
Greetings All,
My girlfriend somehow put a hole in the plastic in her door panel trim. I called the dealership and to replace it we're looking at around $400. I've quoted some online and found a used one shipped for ~$100.
My concern is:
"This is sold as the trim panel only. This does not include any elctrical switches of any kind. It also does not include the door handle."
Will I be able to use the electrical switches and door handle from her current door panel?
Thanks for any help!
Old Mar 26, 2013 | 03:24 PM
connam06's Avatar
End of the workday BUMP
Old Mar 26, 2013 | 04:40 PM
You posted in the wrong forum thread, that's why I moved you to this one..
Old Mar 26, 2013 | 04:42 PM
I would say yes if it's from the same year , make, model that your working on.
Make sure they will take it back if they give you the wrong one or if you ask for the wrong one also..
Old Mar 26, 2013 | 05:25 PM
Sounds like you're not gonna get the little lever that opens the door. Nor any of the window switches, locks, etc. As long as they aren't damaged you should be able to swap them over.
Used one on-line is the right color?
Old Mar 27, 2013 | 07:21 AM
connam06's Avatar
Looks exact to the one she has now. I just needed to make sure the electrical components can be swapped.
Old Mar 27, 2013 | 07:47 AM
connam06's Avatar
Thank you for doing so!
Kelsen
DIY Answers.
Apr 7, 2020 11:46 PM
ProAutoGlassllc
May 21, 2013 12:45 AM
dacecil
Sep 25, 2007 09:21 AM
