2005 Body Control Module?
Old Aug 15, 2022 | 08:24 PM
Rgbtexas's Avatar
Default 2005 Body Control Module?
I shorted out my system being stupid.
  1. no dash lights
  2. Car starts but won't shift out of park
  3. Windows stopped working
Got error codes U0155 & U1102 - both networkNo fuses blown.
I thought it was the ECU so sent it for repair.They said it's fine and are sending it back.
They suggested it's the body control .module BCM but I can't find a reference to it for my 2005.
Any suggestions greatly appreciated.
Old Aug 16, 2022 | 04:26 PM
Which wires were shorted?
Does your accord have a navigation system?
Old Aug 16, 2022 | 05:02 PM
Rgbtexas's Avatar
No navigation.
I'm told it's the MICU behind the interior fuse box that's the issue.
Old Aug 16, 2022 | 05:21 PM
U0155 points towards a f-can communication issue between the PCM and gauge control module. U1102 is a f-can communication error.
I was asking what wires were shorted to figure out what was possibly shorted before throwing a part at it.
Old Aug 16, 2022 | 05:37 PM
Rgbtexas's Avatar
In the 2005 the ECU and PCM are the same unit located behind the center console. I pulled that and had it tested and was found to be good. I called them before I sent it and they said windows and dash lights pointed directly to MICU (body control Unit) but I sent it anyway to make sure.
Looking up indicators it's the MICU seem to match that assessment.
It all started jumping connections to make the driver's window roll up because I couldn't find a master window controller that worked. Ordered one from Amazon & one from Advanced Auto and neither worked.
Old Aug 16, 2022 | 06:49 PM
The MICU can be the problem. There are some CAN tests you can try if you want to see if you can get some more information.
For your issue, I'd recommend getting the shop manual for your car. You can get a pdf for about $22 from automanualsource.com that can help you out with some of the testing.
Old Aug 16, 2022 | 07:06 PM
Rgbtexas's Avatar
Your right. Having that would be a good idea. I'll take a look. I did find some tests to run but I'm finding documents don't match my car.
One of the tests showed using an 18pin connector to the ECU. It didn't have an 18 pin connector. ?
Looking at the owners manual from 2005 does not match either fuse box but does match some images I found for 2003. BUT the VIN says 2005!?!
Old Aug 17, 2022 | 03:31 PM
Rgbtexas's Avatar
@PAhonda
Got the manual. I'm a total NOOB at auto electrical.
I've got a ton of questions:
Page 11-198 for the 2005 Honda Accord
Where do I find the 30P Guage Assembly Connector Terminal - Is it near the Fuse Box or do I have to remove the gauge assembly to get to the back?
Where do I find the 30P ECM connector - fuse box or at the ECM?
Further on it says to use HDS which I don't have. What do you guys do with that?
Sorry for so many questions.
Old Aug 17, 2022 | 07:57 PM
Gauge assembly connector will require removing the gauges. ECM connector is a 30P connector plugging into the PCM/ECM.
This is the frustrating part with newer cars. The steps requiring the HDS are tricky, because you don't have one. Try the non HDS steps to hopefully you'll find something obviously wrong in the system.
Old Aug 17, 2022 | 08:07 PM
Rgbtexas's Avatar
Thanks! Tomorrow's fun.
junior1
Jun 5, 2011 05:12 PM
NJ007
Jun 27, 2010 06:26 PM
LIaccord05
Nov 4, 2009 06:33 PM
Mike_EX
Jan 28, 2007 12:53 AM
