2007 Accord Brake Problem
Old Apr 16, 2012 | 06:10 PM
no21's Avatar
Question 2007 Accord Brake Problem
I drive a 2007 Accord and when I changed the brake pads the pedal almost goes to the floor board when driving. Did I miss anything while doing this because I have also bleed the lines and it still does it
Old Apr 16, 2012 | 06:23 PM
Don't post on existing post w/ new problem.
Were any bleeders cracked during the pad replacement? Did you pump the brakes after replacing pads and get a firm pedal?
Old Apr 16, 2012 | 06:30 PM
no21's Avatar
No bleeders were cracked and after the change I got the regular push back until I started driving again
Old Apr 16, 2012 | 06:44 PM
1. Just to clarify, this problem happened after the pad replacement?
2. Were these the front or rear brake pads?
3. Depending on front or rear, how did you retract the pistons back? For front, pushed back in? For rear, turned?
komar
May 11, 2013 10:33 PM
wa2be
Apr 11, 2013 08:46 PM
elvis1977
Nov 2, 2012 06:42 PM
wolfehunter
Aug 25, 2010 08:51 PM
musicmaniac
May 30, 2008 01:55 PM
