-   -   2007 accord power windows (https://www.hondaaccordforum.com/forum/general-tech-help-7/2007-accord-power-windows-20182/)
dvb108 Aug 17, 2008 06:49 PM
Hi, I have the car in my signature. The driver's window works fine. However, the other 3s power windows stopped working. When I press the buttons, I can hear the click each time but the regulators won't budge. The "window lock" button was released. I also checked the fuse and it's fine. Where should I check next?
Also, could someone give instruction/link on how to open up the door panel? Thank you.
PAhonda Aug 17, 2008 08:55 PM
RE: 2007 accord power windows
I would take it to a dealership, since it should still be under warranty.
Do the windows work when you use the individual switch for each non-functioning window?
dvb108 Aug 18, 2008 06:18 PM
Thank you for your response.
The car has 66000 miles. It's out of warranty.
The individual switches are not working either. Every time a switch is pressed, I can hear a click at the corresponding door.
Anyone know how to take the door apart?
t4lude98 May 30, 2009 11:21 PM
bump for same problem
t4lude98 May 31, 2009 08:06 PM
can someone please help with this
TexasHonda May 31, 2009 08:36 PM
Other than dealer help, you will need a 2007 Honda shop manual. Manual is available from helminc.com for $55. I recently purchased a manual for my 07 Accord and looked at power windows section.
It was not apparent anything would cause common failure of 3 windows. There is a reset procedure for the power windows that is quite extensive which may/may not help.
What happens when you try auto-down function w/ key in driver's door lock or remote button held down? All windows should open. If they don't this would suggest a control system fault. Liklihood of all three windows having a fault at same time is almost nil.
There are 3 DTC's ( DTC B1125, DTC B1126, DTC B1140) that deal w/ power window faults. Not sure how to extract these but probably requires Honda Diagnostic System (dealer tool).
t4lude98 Jun 1, 2009 05:48 PM
thanks for the reply mine is actually an 05 but same exact problem only the drivers window works w/ key in door and w/ remote
i can hear all windows click when i press the button from the drivers door but if i press the button on any other 3 doors no click all fuses good im lost
t4lude98 Jun 4, 2009 05:56 AM
to the top
t4lude98 Jun 5, 2009 08:36 PM
help! lol
Daver Jun 11, 2009 09:36 PM
bump
same problem on my 2007
Yesterday they worked fine on my ride home. got in this morning only drivers side works. I hear the regulators click in each of the other doors. if I engage the switch to disable them I do not hear the click.. damn dealer wont see me until monday at the earliest any ideas?
