2007 accord power windows
Old Aug 17, 2008 | 06:49 PM
dvb108
Default 2007 accord power windows
Hi, I have the car in my signature. The driver's window works fine. However, the other 3s power windows stopped working. When I press the buttons, I can hear the click each time but the regulators won't budge. The "window lock" button was released. I also checked the fuse and it's fine. Where should I check next?
Also, could someone give instruction/link on how to open up the door panel? Thank you.
Old Aug 17, 2008 | 08:55 PM
Default RE: 2007 accord power windows
I would take it to a dealership, since it should still be under warranty.
Do the windows work when you use the individual switch for each non-functioning window?
Old Aug 18, 2008 | 06:18 PM
dvb108
Thank you for your response.
The car has 66000 miles. It's out of warranty.
The individual switches are not working either. Every time a switch is pressed, I can hear a click at the corresponding door.
Anyone know how to take the door apart?
Old May 30, 2009 | 11:21 PM
t4lude98's Avatar
bump for same problem
Old May 31, 2009 | 08:06 PM
t4lude98's Avatar
can someone please help with this
Old May 31, 2009 | 08:36 PM
Other than dealer help, you will need a 2007 Honda shop manual. Manual is available from helminc.com for $55. I recently purchased a manual for my 07 Accord and looked at power windows section.
It was not apparent anything would cause common failure of 3 windows. There is a reset procedure for the power windows that is quite extensive which may/may not help.
What happens when you try auto-down function w/ key in driver's door lock or remote button held down? All windows should open. If they don't this would suggest a control system fault. Liklihood of all three windows having a fault at same time is almost nil.
There are 3 DTC's ( DTC B1125, DTC B1126, DTC B1140) that deal w/ power window faults. Not sure how to extract these but probably requires Honda Diagnostic System (dealer tool).
Old Jun 1, 2009 | 05:48 PM
t4lude98's Avatar
thanks for the reply mine is actually an 05 but same exact problem only the drivers window works w/ key in door and w/ remote
i can hear all windows click when i press the button from the drivers door but if i press the button on any other 3 doors no click all fuses good im lost
Old Jun 4, 2009 | 05:56 AM
t4lude98's Avatar
to the top
Old Jun 5, 2009 | 08:36 PM
t4lude98's Avatar
help! lol
Old Jun 11, 2009 | 09:36 PM
Daver's Avatar
Default bump
same problem on my 2007
Yesterday they worked fine on my ride home. got in this morning only drivers side works. I hear the regulators click in each of the other doors. if I engage the switch to disable them I do not hear the click.. damn dealer wont see me until monday at the earliest any ideas?
