2010 Accord v6 stalls
V6 Accord stalls I’ve changed mass airflow sensor, fuel pump,ignition switch,ac relays,and it still stalls please help |
Originally Posted by Mike Jeffries
(Post 384175)
At minimum get the codes scanned, then do some testing before replacing another part. Post the actual code on here. They start with the letter P and have four numbers, like P1234. Depending on your skill level, we may be able to help you with some tests.
Originally Posted by shipo
(Post 384176)
My suggestion is to stop throwing parts at the problem and have it professionally diagnosed and repaired; it will cost you less in the long run to have it fixed properly.
(Post 384207)
I took it to a shot that only fixes Honda’s they said since there’s no engine light and no codes to change parts that are related til it’s fixed |
I just read that Honda has a recall for my Accords electrical system harness that can cause stalls I’m calling in the morning hope I get good news |
