2010 Accord v6 stalls
My suggestion is to stop throwing parts at the problem and have it professionally diagnosed and repaired; it will cost you less in the long run to have it fixed properly.
At minimum get the codes scanned, then do some testing before replacing another part. Post the actual code on here. They start with the letter P and have four numbers, like P1234. Depending on your skill level, we may be able to help you with some tests.
I took it to a shot that only fixes Honda’s they said since there’s no engine light and no codes to change parts that are related til it’s fixed
Time to find a different shop.
