2013 Accord Recirculation
Old Aug 12, 2013 | 04:00 PM
BocaHonda's Avatar
Default 2013 Accord Recirculation
I previously drove Acura TL & Acura TSX. On a hot day when one put on the AC Auto it automatically started with AC Recirc and then switched off Recirc as the car got cool. With the 2013 Accord w/ Navi the AC goes to AC Recirc, but never switches to fresh air. I have to change it manually. It doesn't matter that the car has reached set temperature. When I change to fresh air, then Auto goes off. So, I either have Auto with Recirc or No Auto / Fresh air. Dealer & Honda cust svc don't have a clue. Is there a way to set the system so that it switches automatically to fresh air? Thanks.
Old Aug 12, 2013 | 05:21 PM
Based on the owner's manual, if Auto climate control is on when the car is running, and you press any button (for example, fresh air), the function of that button takes priority.
The AUTO indicator will go off, but functions unrelated to that button will be controlled automatically.
Essentially, if you press to let fresh air in, even though the Auto indicator light goes off, it is still in auto climate control. Only if you press the On/Off button is auto climate control canceled.
Attached Thumbnails 2013 Accord Recirculation-using-auto-climate-control.jpg
Old Aug 13, 2013 | 08:17 AM
BocaHonda's Avatar
Thanks. Probably designed by engineer who sits in a cubicle and doesn't drive cars he specs.
Old Aug 13, 2013 | 11:22 AM
Nobody listens to engineers. Cars are designed by focus groups, then management dictates which way the engineers shall make it.
Old Aug 14, 2013 | 07:50 PM
BocaHonda's Avatar
I ran many focus groups to evaluate over the counter clinical diagnostic tests. A lot of laughs and a few good ideas.
darkseat
Nov 4, 2013 07:07 PM
mannjn
Mar 2, 2013 09:49 AM
mannjn
Oct 8, 2012 05:59 PM
Jet sitter
Jul 20, 2012 12:41 AM
César Ramos
Nov 7, 2006 12:02 AM
