2014 Accord Rear Window Defogger Ques
Old Feb 12, 2019 | 02:22 PM
69Indian's Avatar
Default 2014 Accord Rear Window Defogger Ques
Does anyone know the correct voltage my multimeter should register when measuring at the drivers side and passanger side connecters of the rear window defogger?
Old Feb 13, 2019 | 09:10 PM
What issue are you having?
There should be 2 wires to the connector. The blk wire is ground. The other wire will have battery voltage, so ~12V.
If you unplug the connector, you should get 12V across the two wires. If you have 0 volts, then you need to determine if the power or ground wire is the problem.
If you get a 12V reading on this static test, the issue could still be the wiring/relay.
Old Feb 20, 2019 | 10:18 PM
69Indian's Avatar
Thanks for the response. I am getting just under 10 volts when measuring at the drivers side with the red multimeter wire and passanger side with the black. The grid does not seem to get warm enough to melt ice and snow effectively.
cukaracha
Jan 21, 2015 05:13 PM
shortduck
Nov 10, 2011 09:40 AM
dragonle87
May 19, 2009 07:58 AM
QnzBurna28
Oct 17, 2008 07:06 PM
Ranmaster
Apr 12, 2008 08:24 AM
