30K service for 2010 Accord
Old Oct 9, 2015 | 08:32 PM
John_W's Avatar
Originally Posted by JimBlake
Drain/fill amount is really only good when the car is level - like on a lift. If you jack up one corner or the other, you can drain out more or less.
The important thing is the dipstick shows the correct amount when the car is sitting on it's wheels on flat ground.
Same with engine oil. I usually drain a little more than normal, because I rotate my tires while it's draining. Lifting up each corner around the car drains out a little more of the dirty oil, which I think is a good thing. Trust the dipstick when it's all done.
Thank you JimBlake for you comments on this. I take your points about relying on the dipstick readings and about the car being level when draining.
harry51894
Feb 2, 2014 02:58 PM
jrasero
Feb 27, 2013 05:06 PM
11040
Oct 29, 2011 12:33 PM
SykVSyx
North East
Sep 25, 2010 01:07 AM
SykVSyx
Canada, Over Seas & Elsewhere
Apr 21, 2010 12:06 PM
