6cd changer wiring diagram needed
Old Aug 8, 2010 | 01:18 PM
orgal's Avatar
Default 6cd changer wiring diagram needed
I bought a second hand 02 plate honda accord but the wiring for the 6cd changer is corroded where the cable from the front connects to cable from cd changer in boot...
I had to cut it the connection and now have all the wires cut back ready to connect but dont have a clue which wire connects to which...
any help or wiring diagrames please...
Old Aug 8, 2010 | 07:21 PM
Hi new Member..
This might take a while for the guys to sort out, so please be paitent...
Old Aug 8, 2010 | 07:37 PM
hondadude's Avatar
So you are saying you shopped out the 14 pin connector just before the changer unit?
You didn't notice the wire colors were different?
I'm not sure there is an actual schematic of that connector because it is accessory wiring.
I'll search connectors and see what I can find.
By any chance did you save the connector? Maybe try to figure it out from that?
Old Aug 9, 2010 | 02:30 PM
orgal's Avatar
Hi, The wiring was well corroded and wires had all fused. I did take a note of where the wires went but wired it up and nothing.
There seems to be a green wire coming from the head unit but no green wire from cd changer.
Also a red wire from cd changer but no red wire form head unit.
There was a black wire soldered to the casing of the connector. It was a round connector with 7 pins round the edge and 1 in the middle.
There was a small green wire connected to the casing too.
Its a Bose system tape with 6 cd. I think the previous owner swapped out the cd unit for the tape and 6cd.
My last accord exec on an 52 plate had a single cd and bose.
Would be good to get the unit working. They also installed a type v steering wheel with audio remote. But the audio remote buttons aren't working. Are these not to do with the sat nav unit as only these seem to have audio controls on the wheel.
Old Aug 9, 2010 | 03:13 PM
So your 6cd changer is in the trunk? Are you in the US?
You can order a new cable for ~$60. These may only work on US accords, I am not sure.
You may be able to find one at a junkyard or on Ebay.
The 2-door part number is 08B11-S82-101
The 4-door part number is 08B11-S84-101
Old Aug 10, 2010 | 06:15 AM
orgal's Avatar
I am in Scotland
Old Aug 14, 2010 | 11:31 PM
Happy Scottish Day to you then...
Old Aug 15, 2010 | 08:13 PM
The sound systems might be different between USA & UK/Scotland.... ?
kirankumar299
May 6, 2011 06:29 PM
01Accord
Oct 10, 2007 03:12 PM
jhowkins
Aug 23, 2007 05:42 PM
wasaland
May 14, 2007 05:03 PM
chico_dA_man
Mar 15, 2007 01:01 AM
