84 accord tacho no worky
Old Oct 22, 2024 | 03:18 PM
MadamXecutioner's Avatar
Default 84 accord tacho no worky
Any suggestions for troubleshooting?
Old Oct 23, 2024 | 11:12 AM
The circuit for the tachometer on the gauge cluster is the ignition coil, the wiring, then the gauge in your cluster. A problem with any of these items will cause the gauge to not work. I'd start with the simplest and check the electrical connection to the ignition coil for any corrosion/poor connection.
The next step would be if you have a volt meter that can read hertz (Hz) or possible in ac voltage mode to see if the meter can pick up the signal in the wiring.
You could also pull the cluster to see if you have a poor connection or cracked solder joints on the circuit board for the tachometer.
dogcatman34
Jul 9, 2012 09:30 PM
LeeB
Mar 11, 2011 06:59 PM
SpentNed
Apr 20, 2007 04:08 PM
exyled
Feb 24, 2007 06:18 PM
duck
Dec 16, 2006 10:18 AM
