87 accord heater controls
The heater control on my my son's 87 accord provides heat only when it is on high, meaning the other settings don't do anything.
I saw a post somewhere else that mentioned something about a resistor pack that might be the problem. Not sure if that applies to this vintage model or not. Would I need to try and take the dash apart to get in behind the heater control levers? Any tips or feedback appreciated. |
RE: 87 accord heater controls
no need to remove dash or heater blower........resistor is located on top of blower assembly,, 2 phillip screws .call dealer ask for a blower motor resistor..
Happy New Year ;) |
ORIGINAL: deserthonda no need to remove dash or heater blower........resistor is located on top of blower assembly,, 2 phillip screws .call dealer ask for a blower motor resistor.. Happy New Year ;) I found the 'blower resisitor' which is located under the right side of the dash behind the blower motor. I removed the 2 screws which held the old one in place but now it seems like whatever was on the other side of the opending to screw the 2 phillips screws back into is no longer there or in position anymore. I mean I can feel some sort of plate or metal flap that is up there (on an angle so maybe that got shifted somehow) but I have no visibility to see what is going on nor do I know what I should be screwing those screws into. I thought it was just an empty hole but that doesn't seem to be the case. Clear as mud? Any help appreciated. |
Here is an exploded view of that area.... might make more sense.... Gotta love those vendors!
http://www.hondapartswarehouse.com/p...t6=B%20%201702 |
I did manager to find something similar that showed me an explode view so I figured out I had just bumped the internal housing which I needed to screw it into. Not the best design in my mind but it is now working!
Thanks for the help all. |
