87 left driveaxle question
ive got a 87 honda accord and the driver's side CV is old. I have a drive axle from an 86; does anyone know if I can use the 86 for the 87?
RE: 87 left driveaxle question
As long as the cars both have the same transmission, it should work. You just can't go AT->MT and vice versa, the axle lengths are different.
And thanks for joining the forum:D
For interchanges like that I usually go to http://www.autozone.comand type in the make/model/year/engine/transmission info for the first car and then add the part you are wondering about to your online cart. Then add a vehicle and enter all of the same info for it and look up the same part again. That will show you if it is the same part number.
Derek |
1987 4dr LX AT L-side: 06444-SE0-505RM
1987 4dr LX MT L-side: 44306-SE0-912 1986 4dr LX AT L-side: 06444-SE0-505RM 1986 4dr LX MT L-side: 44306-SE0-912 Those are Honda part numbers, they match up so go right ahead and use the '86 driveshaft you have! |
