88 Honda Accord
I own an 88 Accord. It was parked for aboout 8 years and we have now been trying to get it to run. We have replaced the fuel pump mutiple times and is now runing. I can not get the car to start though unless i pour gas into the carb and when I get it started it will run for several minutes and then it will die and I have to do the same thing as before to start it. We have replaced the relay unit which is located above the peadles. My question is is there another relay unit located somewere on the honda or am Iruning into a different problem?
have checked the fuel filter.
I have a 91' and after it sat for a few years it needed a new filter 'cause it wouldn't start with out starting fluid. Just a quick idea.
You should be able to hear the pump prime when you turn the key on. When the car is running you should always hear the pump.
Yes. All of the filters in the car are brand new, and when you first turn the key on the pump starts and then stops and when you have the car runing the pump is as well. When the car dies how ever I notice that the pump is no longer running, and I am not sure what causes the pump to stop. We have replaced the relay above the pedals, and the folks at napa say that there is two relays in the car, but they did not no were. If that is the case I need to find that realy and replace it, but I am not sure if that is the case because napa has told me this on a different car and it turned out that it only had one.
We have cleaned the tank out and it has good gas. The carb is good and the engine will run if i am pouring gas into the front and sometimes when i stop the gas pump will maintain the engine. The carb is running out of gas though and something is shutting off the pump. We have replaced the relay above the pedals, and when we were at auto parts they said that there was a second relay but I am not sure if i trust that because they told us that on a different car and they were wrong. I know the wire is good running to the pump so I dont know why the pump stops sending gas to the carb...
I do not know how to check if there are any codes and because it is 23 years old i don't know if it would even have any.
In the common DIY thread on top of the gen tech help forum, there is a link to online shop manuals. You can get a manual for an 86 accord from the honda tech link. That should be the same as your 88.
What I think you need to do is verify that the pump is losing voltage.
On page 11-76, it shows how to jump the fuel cut off relay. I would try that without disconnecting the fuel line and see if the car keeps running.
The other way would be to back-probe the yellow wire going to the fuel pump. Hook up a volt meter or 12V test light to ground and see if that wire loses power when the engine cuts off.
