89 accord HELP!!
Old Dec 24, 2006 | 08:01 AM
ahmad89's Avatar
Default 89 accord HELP!!
I need help on two things, how to change the front driver side turn signal on the bumper and when i pull or push the rear side window buttons under the high beam and the defroster buttons, it doesnt do anything how do i fix that?
Old Dec 24, 2006 | 02:49 PM
deserthonda's Avatar
Default RE: 89 accord HELP!!
ORIGINAL: ahmad89
there is a phillip screw either sideways or you can get to it from underneath . losen the screw and pull out the lense
As for part 2 i am not sure i totally undrstand what you are saying ..rear side window button ???
Old Dec 24, 2006 | 03:25 PM
ahmad89's Avatar
could you show me where those screws are?
Theres a button or lever for the rear side windows if you push it the windows open if you pull it back the windows close. The windows are like triangles right behind the main windows.
Old Dec 24, 2006 | 11:58 PM
Chiovnidca's Avatar
ORIGINAL: ahmad89
I think you have to pull out hte access panel under the bumper to get to it.
Old Dec 25, 2006 | 06:28 AM
ahmad89's Avatar
well also how do i get my rear windows to work? i had an 89 accord DX coupe. I push the button or lever to open and close the rear windows and it doesnt do anything i have to manually open it. How do i fix this?
EDIT: i replaced my turn signal bulb i jsut need to get my rear windows to open! Would a fuse fix this problem? when i look at the chart diagram and then look at the fuse layout, theres nothing there for the windows...
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
