-   -   89 accord please help!!!!!!!!!! (https://www.hondaaccordforum.com/forum/general-tech-help-7/89-accord-please-help-2249/)
cory Mar 8, 2006 07:38 AM
89 Accord having trouble with car intermittently jumping and bucking on the interstate when you are in the throttle. When you lift off the throttle the problem quits. Car is carbureted and has 222,000 miles on it, but has great maintenance records on it. please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sir_nasty Mar 8, 2006 01:09 PM
RE: 89 accord please help!!!!!!!!!!
did it just start out of the blue one day? Do you normally run at least 1/4 tank of gas? Does it do it anywhere but the interstate or is it only at higher speeds?
cory Mar 8, 2006 02:47 PM
it just started doing this a couple of days after I bought it. It has happened between 40 75 mph. It doesn't do it say from a stop sign where the motor is really loaded to move the car. It has happened with a full tank or half, it doesn't seem to care. thanks! please help!!!!!!!!
sir_nasty Mar 8, 2006 03:13 PM
Well I'm a guessing person so I'd guess it's a fuel or ignition issue... How long have you had the car? Possible junk in the gas tank, fuel filter issue... I like to start small, if it hasn't been tuned up (plugs/wires, cap rotar etc...) lately I'd do that as well as a fuel filter and a bottle of fuel injector/carb cleaner... You should get some better responses shortly if this is something you've already done....
mbo1985 Mar 8, 2006 08:19 PM
You might need to clean those carb jets. Other wise I'd check fuel filter, plugs and cap and rotor.
How do your spark plug wires look?
deserthonda Mar 9, 2006 02:30 PM
ORIGINAL: cory
remove the air cleaner, on the back of the carb, below the idle solenoid, there are 2 vacc hoses , that if broken will cause exactly what you are experiencing, bucking at 40-60 mph,,
take a good look at them, replace if cracked or broken, put together, test drive,,
post the results
