89 accord please help!!!!!!!!!!
Old Mar 8, 2006 | 07:38 AM
cory
Default 89 accord please help!!!!!!!!!!
89 Accord having trouble with car intermittently jumping and bucking on the interstate when you are in the throttle. When you lift off the throttle the problem quits. Car is carbureted and has 222,000 miles on it, but has great maintenance records on it. please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 8, 2006 | 01:09 PM
sir_nasty's Avatar
Default RE: 89 accord please help!!!!!!!!!!
did it just start out of the blue one day? Do you normally run at least 1/4 tank of gas? Does it do it anywhere but the interstate or is it only at higher speeds?
Old Mar 8, 2006 | 02:47 PM
cory
it just started doing this a couple of days after I bought it. It has happened between 40 75 mph. It doesn't do it say from a stop sign where the motor is really loaded to move the car. It has happened with a full tank or half, it doesn't seem to care. thanks! please help!!!!!!!!
Old Mar 8, 2006 | 03:13 PM
sir_nasty's Avatar
Well I'm a guessing person so I'd guess it's a fuel or ignition issue... How long have you had the car? Possible junk in the gas tank, fuel filter issue... I like to start small, if it hasn't been tuned up (plugs/wires, cap rotar etc...) lately I'd do that as well as a fuel filter and a bottle of fuel injector/carb cleaner... You should get some better responses shortly if this is something you've already done....
Old Mar 8, 2006 | 08:19 PM
mbo1985's Avatar
You might need to clean those carb jets. Other wise I'd check fuel filter, plugs and cap and rotor.
How do your spark plug wires look?
Old Mar 9, 2006 | 02:30 PM
deserthonda's Avatar
ORIGINAL: cory
remove the air cleaner, on the back of the carb, below the idle solenoid, there are 2 vacc hoses , that if broken will cause exactly what you are experiencing, bucking at 40-60 mph,,
take a good look at them, replace if cracked or broken, put together, test drive,,
post the results
LONO100
Aug 11, 2012 06:21 PM
esan805
Mar 29, 2012 02:33 PM
art vandelay
Aug 2, 2010 09:29 AM
mamtsberg
Mar 17, 2010 09:15 PM
BIGWILBO
Apr 5, 2008 07:57 PM
