90 accord fan is always on
When I come to a stop, and Im sitting there for slightly over a minute, the temperature gauge begins to read hot. The needle moves from mid-way cold/hot up to hot. Then the fan turns on and it still reads hot, only when I begin to move the needle goes back to normal temperature. Why does the car read so hot when I sit there? Could it be that I had the radiator replaced and somethings missing? Or I need to check the o2 sensor? Also, when I turn my car off, the fan stays on for about 5 minutes or so.Any help would be greatly appreciated!!!
RE: 90 accord fan is always on
You likely have a non-working thermoswitch A (turns cooling fans on at about 190F). Thermoswitch A is on the thermostat housing behind the distributor. Remove the electrical connector to the switch and short the connector w/ a wire jumper. Both fans should run continuously as long as keyswtich is ON. A new thermoswitch A should fix your problem.
If operating temp is normal at forward speeds, the thermostat should be OK. If not, you might replace the thermostat at same time. It is normal for cooling fans to run w/ keyswitch OFF, if the coolant temps are a bit high. This prevents too much heat soak overheating of the cylinder head which can damage the head gasket. good luck |
Is the replacement rad significantly smaller than the original? It sounds like the thermoswitch is bad if it takes too long to turn on the fan.
so it is normal for the fan to run once the car has been turned off...I dont usually hear newer cars doing that, I thought it was the 90 old school honda way of cooling off. Can there be a significant problem that may occur if I do not change the thermoswitch A, if it is the problem?
personally i consider the fans running with the engine off abnormal unless it's a hot day. if you don't change the thermoswitch in the thermostat housing you can damage the head gasket and need possibly need a new head or block if warped enough. that is assuming the thermoswitch is the problem.
to find out - disconnect the thermoswitch and jump the two terminals in the connector with the key on engine off. both fans should run. if they do, replace the switch and road test. consider replacing the thermostat since the engine has already overheated a few times. |
ORIGINAL: LandonHondaAccord When I come to a stop, and Im sitting there for slightly over a minute, the temperature gauge begins to read hot. The needle moves from mid-way cold/hot up to hot. Then the fan turns on and it still reads hot, only when I begin to move the needle goes back to normal temperature. Why does the car read so hot when I sit there? Could it be that I had the radiator replaced and somethings missing? Or I need to check the o2 sensor? Also, when I turn my car off, the fan stays on for about 5 minutes or so.Any help would be greatly appreciated!!! |
