-   -   90 Accord fuel or ECU problem? (https://www.hondaaccordforum.com/forum/general-tech-help-7/90-accord-fuel-ecu-problem-52147/)
motogar Jan 1, 2013 05:39 PM
First thread folks, correct me if I do it wrong.
I ran my 1990 Accord fuel level low untill warning light, since that time I have what acts like a fuel starvation problem. Bogging, no power.
This problem occurs at about the same point of operation every time the vehicle is restarted. The problems is for a short duration, and the motor clears and runs fine. Fuel pump and screen, fuel and fuel filter have been replaced. There has been an occasional "chk engine" light, that resets after operation. I have not check stored codes. I was hoping for the magical fix!
TexasHonda Jan 1, 2013 07:43 PM
Check Engine light codes must be determined to diagnose. See DIY forum for guidance on Obd1 code extraction.
Magic fixes are guesses and can be expensive. If this is a "cold engine" only problem, I would suspect a false input; Inlet Air Temperature or Coolant Temperature. The CEL code should identify the problem.
WheelBrokerAng Jan 2, 2013 12:37 AM
Hi New Member.
Your now in the correct thread to post these kind of questions.
Thank You for joining the HAF...
WheelBrokerAng :)
motogar Jan 2, 2013 08:46 AM
Thank you for the replies, I will be checking codes to diagnose more. I was crossing my fingers on the quick fix.
JimBlake Jan 2, 2013 12:43 PM
Keep your fingers crossed, it MIGHT STILL be a quick & easy fix. But without knowing the error codes, we have way too many possibilities to guess.
