'90 ex...
Where's the fuse for cig. lighter? A cell charger was plugged in and the sprung end came apart, un-noticed by me. Went to plug a different item into the socket...after it wouldn't go, took a look and found the piece inside. Socket doesn't work now, but can't find the fuse listed in Hayne's manual. Dome light and trunk light also out...no fuse location listed for these either. Help?
dome light, trunk light & lighter = underhood fuse box fuse#22 /15 amp
EDIT; there is also a thermal link inside a plastic case on the back of the lighter socket. It can be resoldered
#29 in the fuse box under the hood. 15amp. See attached pic.
EDIT: just saw hondadude's post. The info I got was from the 93 accord shop manual. It should have labels describing the fuse under the cover or in the owner's manual.
