91 Accord EX F22A4 Electrical issues, No Start
Old Apr 7, 2012 | 08:10 PM
  #21
shizoma's Avatar
Checked everything went back to square one 150 psi min all cylinder all four fire physically watched injectors go.....s light blinks no more likely cause I cleaned and tightened all terminals.....please halp checked ect good checking gps now...please lord help going crazy thanks pahonda
Old Apr 7, 2012 | 08:56 PM
  #22
Spraying starting fluid into the intake would kind of rule out fuel. Plus you see the injectors spraying fuel.
This has to be a spark or a timing problem.
Did you check that the tip of the rotor is pointing towards the #1 spark plug wire at top dead center?
Are the spark plug wires installed in the correct order (1, 3, 4, 2)?
Old Apr 7, 2012 | 09:23 PM
  #23
shizoma's Avatar
I did state earlier that I actually removed the valve cover to verify timing so yes that means the distributor also......thank you so much for your help not sure if it should but to the map sensor I have 12v hot on the y/b and the other wire.....least I believe its map the black box under the intake I have a .33v negative no key on then 0v with key on dude I can guarantee this is not timing this is a sensor or ground issue although I have removed and cleaned and tightened all grounds and considering this is the second new distributor I put in because the first one I got had a bad reluctor in it I am losing more hair by the hour lol the iat has 5v key on......snarf!
If its timing its not mechanical timing issue
Old Apr 7, 2012 | 09:38 PM
  #24
shizoma's Avatar
Ok map sensor on firewall checking it now tps good iat good ect good.....
Old Apr 7, 2012 | 09:39 PM
  #25
The reason I asked about the distributor is that it is possible to install it 180 degrees out of time. The key is offset, but I have done this before.
Old Apr 7, 2012 | 10:09 PM
  #26
shizoma's Avatar
No worries yeah the first one I bought was out but I actually had to remove the pin and physically move the teeth around to fix it being 180 out but honestly I did check to be sure it actually idled for a minute yesterday......so one thing I found weird.....there is a light beep with the key on and whether the tps is hooked up or not the noise stops if I move the throttle just off its stop the beep goes away...
Old Apr 8, 2012 | 10:13 PM
  #27
shizoma's Avatar
Made some headway at least s light no longer blinks fuel pump gets 12v koeo for two seconds its really trying to run I think the damn remained distributor is crap I am going to replace it with a honda distributor and touch back I did all the tests and I will fact even fixed my map sensor yay....just to get it to start now
Old Apr 9, 2012 | 12:51 PM
  #28
shizoma's Avatar
Question
I forgot to add that the thing did run albeit badly prior to changing the distributor......
Pondo
Apr 7, 2012 02:19 PM
mikepolo
Nov 27, 2011 05:38 PM
hmd810
Mar 18, 2009 08:35 AM
eband00
Dec 29, 2008 01:55 PM
Gastongo
Feb 25, 2008 05:03 PM
