91 Accord Heater Problem
Old Sep 27, 2007 | 11:42 PM
Biggie's Avatar
Default 91 Accord Heater Problem
Hello:
My 91 Accord Ex blows cold air throughout the summer. My A/C works perfectly but now that the weather is changing - I found that my heating doesent work. I turned the **** to full heat and all I get is cold air...as in the fan - without any heat.
Im at a loss to understand what the problem is because my ac works fine, yet the heat doesent work. Can anyone please help me out?
Thanks
Old Sep 27, 2007 | 11:48 PM
deserthonda's Avatar
Default RE: 91 Accord Heater Problem
first off chk the **** make sure it is not broken thus not even turning the switch,, if **** is ok,, , make sure that the heater valve works properly,, have someone turn the **** from hot to cold while you watch the heater cable open and close the heater valve properly,, if that works ok , next thing you might want to chk, is to make sure that the t-stat works properly and not stuck open or missing
If heater valve DOES NOT open and close properly you need to chk to make sure that the cables are attached and or adjusted properly ..
MartyH
Nov 2, 2013 10:13 PM
steelworker
Nov 23, 2012 02:08 AM
NY_Pito_NY
Oct 23, 2012 11:15 AM
donkeydawn11
Jan 12, 2010 09:17 AM
vishnuo
Dec 3, 2007 01:39 PM
