91 Accord idles at 3000
Old Oct 21, 2011 | 03:56 PM
Hick's Avatar
Default 91 Accord idles at 3000
Important stuff: 91 accord, 5 spd, 226000 miles.
I was driving the other day and all of a sudden it started to bog out, id rev it all the way up to 2500 and as soon as i let out the clutch it would try to die. Soon after that the idle stuck at 3000. I can rev it higher, but with no throttle pressure it idles at 3000. If i unplug the IAC it bounces between 1000 and 1500. Any suggestions?
Old Oct 21, 2011 | 06:09 PM
Any recent work done? Any stored codes?
From there, check the linkage for free movement-have you actually tried to "gently" close it by hand. While there give the tb a good cleaning-both sides of the butteryfly and where is closes off on the inside of the tb.
Old Oct 23, 2011 | 04:26 PM
Hick's Avatar
The PO just put in a new clutch. and it gave me code 43
Old Oct 23, 2011 | 05:19 PM
After this, know that you prob have an o2 issue.
flomasta
Feb 14, 2013 09:43 AM
ebarrera661
Jan 22, 2010 08:52 PM
ebarrera661
Jan 16, 2010 08:13 PM
Cusm2012
Mar 23, 2009 06:01 PM
OneHundredPercent
Aug 21, 2006 11:09 PM
