91 accord: oxygen sensor bad
Old Feb 6, 2009 | 03:26 PM
jackfast's Avatar
Default 91 accord: oxygen sensor bad
according to my reading of the fault codes, i have a bad O2 sensor.
price for a new one is over $100.
can i get one from a junkyard off a newer model accord?
do i have to stay with 90-93 models?
Old Feb 7, 2009 | 03:43 PM
drummer1279's Avatar
thats a tune up part. used ones are not worth it and yes you pretty much have to stay within your generation.
Old Feb 7, 2009 | 05:21 PM
RogerB34's Avatar
Default 91 Oxy Sensor
Check Bosch at Rock Auto for upstream OEM for around $50.
Should have been changed 100k miles ago.
Old Feb 7, 2009 | 07:05 PM
If you're game to perform a little wiring, you can order a universal O2 sensor off ebay for <$50 bucks and splice to your old O2 wiring harness. I've done this several vehicles w/ no problems.
Old Feb 7, 2009 | 07:10 PM
Wink
Texas Honda has a good suggestion..use that instead of going for the junk yard part...
Old Feb 8, 2009 | 09:16 AM
jackfast's Avatar
after reading some other posts, are there two oxygen sensors?
if so, which one would be indicated by the diagnostic codes?
(41)
Old Feb 8, 2009 | 02:37 PM
No, only the 96 and later vehicles w/ OBD2 systems have two oxygen sensors; fore and aft of the catalytic converter. You only have one ahead of converter.
Old Feb 9, 2009 | 07:40 AM
And, code 41 is for the heater built into the sensor. Take a multi-meter & measure resistance between the 2 same-color (black?) wires of the sensor. It should be between 10 & 40 ohms. If that's OK, then the problem is in the wiring of the car.
Old Feb 10, 2009 | 12:29 PM
f allen's Avatar
Default sensor
probly the ports are stopped up, mine did the same thing, the mech told me he needed to clean the ports, he did and problem fixed, he said 90% of the time thats the problem with the 90 to 93 accords. you may want to get that checked out
Frank Allen 92 accord
Old Feb 12, 2009 | 03:14 PM
jackfast's Avatar
i will check both these and report back.
thanks!
3dw1n
Jan 14, 2015 01:53 AM
giulio76
Dec 29, 2012 11:16 AM
Deckj0122
Jan 8, 2011 10:34 AM
dmost30
Sep 8, 2008 12:42 AM
dmost30
