91 accord: oxygen sensor location?
Old Feb 20, 2009 | 04:14 PM
jackfast's Avatar
Default 91 accord: oxygen sensor location?
i need to change it, or at least clean it.
is it accesible from the engine compartment?
any tricks to taking it out?
Old Feb 20, 2009 | 04:23 PM
finch13's Avatar
You'll need an open ended wrench or an O2 sensor socket. It's right on the exhaust manifold. If you look down, between the radiator fans and the engine block, it's right there sticking out.
Old Feb 20, 2009 | 04:46 PM
jackfast's Avatar
Thumbs up
many thanks!
i am on it!
Old Mar 5, 2009 | 07:14 AM
jackfast's Avatar
i cant find it!
(1991 accord)
is there another location or am i just being blind?
Old Mar 5, 2009 | 08:11 AM
It's in the downpipe, shown as #27, pretty much where it joins from 2 into 1 pipe. Later years it's up in the manifold.
Old Mar 5, 2009 | 08:17 AM
jackfast's Avatar
thanks!
access from underneath then?
Old Mar 5, 2009 | 08:36 AM
I never had a 91, but I guess it would be easier from underneath.
Old Nov 26, 2014 | 08:48 PM
Jorje.Parsad's Avatar
Default how do I disconnect the harness from the top or bottom
im about to swap out my O2 sensor what is the easiest way to disconnect the harness from the top or the bottom ?
Old Nov 26, 2014 | 09:05 PM
From the bottom.
Attached Thumbnails 91 accord: oxygen sensor location?-oxygen-sensor.jpg
3dw1n
Jan 14, 2015 01:53 AM
AcidGod
Feb 24, 2009 01:44 PM
dmost30
Sep 8, 2008 12:42 AM
dmost30
mdjohn
Feb 18, 2006 04:28 PM
