91 accord slow acceleration
Old Jun 16, 2011 | 08:42 AM
pennix3's Avatar
Default 91 accord slow acceleration
i got in the car to go to the store today and when i put the car in drive i and took off it felt sluggish like it diddnt want to go and then it stall out
Old Jun 16, 2011 | 11:47 AM
Pretty thin description.
Does car restart and idle OK, or completely dead? Does engine turn over but not start?
Have you checked battery voltage?
Any recent maintenance; spark plugs, spark plug wires, distributor cap, rotor?
Is Check Engine Light on? If yes, go to DiY section for guidance to access codes. Post your codes for help.
Old Jun 16, 2011 | 12:35 PM
pennix3's Avatar
the car restarts and idles for a min or 2 then cuts off
Old Jun 16, 2011 | 06:52 PM
When engine stops does Check Engine Light and Alt Light come on? If not, it may be a faulty keyswitch assy.
Check for spark when engine will not start. A timing light attached to one lead will indicate spark; no flash = no spark.
Old Jun 17, 2011 | 01:21 PM
pennix3's Avatar
just pulled the spark plugs and all off them had oil on them but the one closest to the distrubtor was filled with oil plug wire and spark plug was drench , so do i need to buy a valve cover gasket set
Old Jun 17, 2011 | 04:52 PM
A valve cover seal set will stop the leaks, however may not be source of your poor performance. I've seen some pretty bad leaks on mine w/ no missing, and would not explain complete cut-off.
Miss Informed
Oct 30, 2014 12:59 PM
frankiep17
Jun 1, 2013 01:06 PM
Pat61
Apr 20, 2012 03:21 PM
fasundrani
Apr 20, 2012 03:15 PM
bob91
Apr 23, 2010 11:33 AM
