91 accord upper ball joint
Old Jun 20, 2011 | 03:18 PM
jlt280's Avatar
Default 91 accord upper ball joint
I was looking at replacing the rotors and one thing I noticed after watching a youtube video on replacing honda rotors of this vintage (cause who woulda thunk you had to pull off the spindle to change a rotor) was that my upper ball joint (front end) does not appear to have a castle nut on it as I am used to seeing on every other ball joint I have ever seen. On this accord, it looks like there are two bolts and a "cap" that bolt onto the spindle and hold the upper ball joint to the spindle assembly as opposed to a standard castle nut and cotter pin.
All of the replacement uppers (even with control arm) that I have found all have a castle nut on the end of the ball upper ball joint. What am I missing here?
Any chance there is a castle nut under the "cap" I described above?
Old Jun 20, 2011 | 04:30 PM
That is just a cover to protect the ball joint. There is a castle nut under that cover.
tlhfirelion
Jun 13, 2011 02:46 PM
stonie1
Aug 18, 2010 06:48 PM
Eddietee20
Jun 10, 2009 05:00 PM
Hoang_Nguyen
May 13, 2007 10:13 AM
wietgr
Feb 11, 2007 07:27 AM
