91 cruise control
Old May 4, 2006 | 03:34 PM
brownstreak's Avatar
Default 91 cruise control
I have a 91 accord LX. I have been trying to get my cruise control working for the longest. I need help!! Ive checked all the fuses and connections I checked the buttons on the steering wheel and dash. if I push in were the cable goes on the canister I can get it to build some pressure. when I pull the vaccume tube off it makes a hiss so I think that the vaccume still works. What else should I check or look for?? is this a common problem for the 90s accords?? because my friend has a 90 ex and has the same problem. would it be expensive to replace the cruise control parts if I needed to?? I would like to get this fixed as soon as possible because I have to do alot of highway driving.
thanks
Old May 4, 2006 | 04:45 PM
s_mackenzie10's Avatar
Default RE: 91 cruise control
I have a '91 EX-R with the same problem where the crusie control doesn't work. I figure I'll just take mine into a garage and pay for it because like BROWNSTREAK, I've checked all the fuses and cables and nothing seems to be helping.
Sean
Old May 4, 2006 | 07:02 PM
sir_nasty's Avatar
alright I got the manual pages for your car.... full troubleshooting procedures/testing for the Cruise control... PM me your e-mail address or post it and I will e-mail it to you (it's in PDF format)
Old May 4, 2006 | 07:32 PM
Thanks sir_nasty. The email is s_mackenzie10@hotmail.com
Sean
Old May 4, 2006 | 08:47 PM
sir_nasty's Avatar
I just sent it to you. Let us know what the resolution is if you fix it
Old May 5, 2006 | 02:06 PM
my E mail is MMTeo21@msn.com hopefully it will put an end to my frustration.
thanks
matt
Old May 5, 2006 | 04:20 PM
sir_nasty's Avatar
hook us up with the fix! it's sent
Old May 8, 2006 | 08:35 PM
o hell yea!!! this helps thanks alot ... I will reply if i can fix it
thanks
matt
Old May 2, 2007 | 11:52 PM
treyshonda
let me know if you fix it, im having same problem on my 1991 honda accord ex, none working cruise control and i have checked everything!
deckerhonda
Jan 24, 2006 09:12 PM
wskipper
Nov 19, 2005 03:49 PM
SeminoleB
Nov 9, 2005 01:52 AM
rabbit
May 3, 2005 01:28 AM
austinbc1
May 2, 2005 08:16 PM
