91 SE Cooling Fan won't stop
Hello-
One morning, I awoke to a sound in the garage, the Secondary cooling fan was running! I pulling the Relay, disconnected the battery to clear the computer. That night I came home and searched the Web and someone suggested that the Relay was bad. Went to the junk yard, got two relays. The next day the fan was starting and stopping! The realy was hot. I found the Water Coolant Sensor and replaced that. Fixed the problem for 2 weeks. Today I went to a hockey game and came back to the car and the Secondary fan was running again, it's cold in Minnesota now. Checked the Relays with the Power Windows Relay, works fine!?! The wires going into the realy box look a little corrided, but everything else works fine. Any Suggestions on with to check next? Thanks, Doug |
RE: 91 SE Cooling Fan won't stop
Okay Guys and Gals-
I see that alot of you have seen my question and nobody has figured this issue out. I replaced one sensor last month. The Radiator Fan Switch Sensor is on the Thermostat Housing. I ordered one last night and going to install it tonight. I am hoping this is the problem since I was stuck at work with a DEAD battery after the Stupid fan ran ALL Day. Luckily my wife made the long drive to Jump Me...er...the Car battery, I mean. I'll keep you all posted with this problem and hopefully the solution. Doug |
I went to the Library and downloaded the cooling system for the honda.
I may have a faulty COOLING FAN TIMER MODULE/UNIT. According to the diagram it looks like it's on the fire wall. I looked for it there and found nothing. I think it's on the driver's side, just below the dash. Black Box with a green wiring connector. About the size a looks of Cigarette pack. Would anyone know where it is for sure?!?! |
...nice going parts changer!! ;) please dont take this offensively!
...keep spending money on new parts dude! this is SOOO wrong! I mean no harm - but you would really wanna stay away from a person who is a part changer - you will spend more and more money just by someone's guesses this practice is wrong! and this is my opinion! P.s. up to you ofcorse [:o] |
you wanna fix it the easiest and cheapest way, yet still have it functional? i would go to the parts store, buy some 20ish gauge wire and a switch..mount the switch inside the car, and run wires to the fan, and make it manual control. thats what i have on my drag car...but thats just me.
wow... what a mickey mouse fix that is.... [:'(]
if any of my customers recieve that kinda fix - he would shoot me and burn our garage down but hey...whatever works ;) 04/29 Added: Yes this is a wrong fix - I do not agree with that and I will never recommend to someone do that! absolutely wrong! there is a right way to test each electrical part -- and I guarantee you that all those parts that you've changed was unnessesary. If you still have the problem please reply and we'll start from there... |
Well Guys, I may have been a parts changer. But I got stuck at work one day because of the Timer unit keep the fan going all day.
Once I figured out which unit was truly the Timer unit....Picked one up for a Whoopin' $5 @ a bone yard! This fixed this problem. This gained me two things. I fixed the car. Learned where to turn to learn about the car and how to fix it. Thanks for the advice...but I had to figure this one on my own this time. |
hey mega, can you post up the location of the last part you changed? i'm having the same problem now and want some guidence if you can offer it.
thanks! chris<pixelmonkey>:D |
so from what i can tell with my problem (same thing) is that its either the ignition switch or the cooling fan timer unit. i looked everywhere trying to find it and just cant see it. is it closer to the firewall or the left side or the steering column etc? also, if i unplug it, will it stop running? just want to make sure i test it first, as i took the advise given to me and changed the relay and the sensor already. the other parts are more expensive and harder to change out, so i really wanna make sure i change the right parts this time lol. right now im just pulling the battery terminal and im getting tired of doing that
Originally Posted by drfraser
(Post 306764)
Is the problem that your fan is running constantly after the car is shut off? |
