91 SE Right upper Turn signal bulb
Old Mar 13, 2005 | 08:08 PM
mega502's Avatar
Default 91 SE Right upper Turn signal bulb
I have been trying to Figure out how to replace this bulb. I have looked at the Chilton's book with no real help there.
To replace that bulb do you have to remove the WHOLE Headlamp assembly?
Thanks,
Doug
Old Mar 14, 2005 | 04:32 PM
Default RE: 91 SE Right upper Turn signal bulb
Hi ...
1st thing you will need to do is get some one with smaller hands, preferably female or small man , remove your battery if it's on that side and then you will have it made.
The bulb socket which you get from behind the hood not in front has a clip that comes off no too easy sometimes and thats after you unscrew the plastic retaing piece that holds it in..
If your still at a loss after that, go to an AutoZone or Advance parts store and they will show you whre to go at it..
Later Member
Old Mar 17, 2005 | 10:44 PM
mega502's Avatar
I figures it out, and broke the light fixture. One screw and plastic pegs holds the fixture in place. It turned out that the light socket does not work. It's not worth the time to fix that light socket.
Thanks,
Doug
Old Mar 19, 2005 | 12:30 PM
Your welcome and I TOLD YOU to watch out for that little clip and you broke it, shame on you.
It's hard not to break that clip, seems to want to break...and of course it does...
Stay with us in the forum and add more of what your doing to your ride...
WheelBrokerAng[sm=gears.gif]
GregRice
May 22, 2011 01:33 PM
IslandAccord
Mar 9, 2009 03:56 AM
bmacb
Dec 28, 2007 10:09 AM
sskkf
Jan 19, 2007 04:23 PM
88accord
Nov 29, 2006 07:35 PM
