91 Starting Issues
Old Nov 12, 2012 | 03:58 PM
Carters1106's Avatar
Default 91 Starting Issues
So im having the same problem. i thought it was the starter, but i had mine checked and it was fine. batter is good had it checked also. when i turn the key i can here a couple clicks like a relay or solenoid but the starter bendix does not pop or try to turn. i thought motor might be locked up so i puxhed started the car and it ran fine. i am stumped and cant not figure it out. any help would be appreciated.
Old Nov 12, 2012 | 04:01 PM
i have a 91 accord and battery is good, so is starter had both tested at a shop. when i turn the key i can here a click like a relay or solenoid but start does nothing. i thought maybe motor was locked up so i push started at and it ran fine. im stumped and cant figure it out
Old Nov 12, 2012 | 05:21 PM
also where is the starter cut relay located?? im just trying to cover all my bases. my car is a manual. how do i check the neutral safety (the clutch relay)?
Old Nov 12, 2012 | 06:15 PM
Test for 12V on that small wire. How was the starter tested?
Old Nov 12, 2012 | 06:27 PM
I've moved all of the posts from the OP into this thread.....so it might read funny.
Slowaccord
Aug 28, 2007 08:38 AM
sir_nasty
Feb 7, 2007 04:19 PM
MRMASON
Oct 3, 2006 07:09 PM
brad6841
May 22, 2006 09:38 AM
brad6841
Apr 13, 2006 06:20 AM
