91: timing belt inspection
how in the world do you get the timing belt cover off for a visual inspection?
mine is held on by two 10mm bolts; the right hand one is accessible, the left is not. is there a trick to it? do i need to remove another part to get access? is this a job for a pro instead of me? |
It's just recessed, so you probably have to get a skinnier socket?
http://www.hondaautomotiveparts.com/...13SM40_E11.gif |
The valve cover traps the upper timing belt cover. It must be removed to lift the upper timing belt cover. The bolts are accessible w/ socket and short extension. A 1/4" ratchet and 10mm socket may help.
If you need more room from the engine mount, you can remove the mount while supporting the engine w/ a jack under the oil pan. Use a board to spread jack load. Manual does not mention this as necessary to remove upper timing belt cover. Inspection of timing marks will require turning the engine w/ the crankshaft pulley bolt through the opening in the wheel liner. Timing mark on flywheel is under rubber boot on front of engine. Inspection of a timing belt for wear is not practical and does not give an indication of a "worn belt". A belt could look fine and break due to brittle nature of material (aging and heat). good luck |
thanks to both responses.
i think it best for a pro to take a look... |
1 Attachment(s)
Well I know what a bad T-belt looks like.
If the teeth have any cracking at the base, replace the belt. With the top cover removed you can shine a strong flashlight into the lower cover and look at the inside of the T-belt where it goes around the tensioner. |
