92 Accord ABS Code
Hi everyone
I just jumpered the connection on the pass side for the diagnosis of why my ABS light comes on 10-20 sec after I start driving. The ABS light came on for like 2 sec, then went out, then flashed once, pause, flash once, pause then flashed once again, then didnt light back up until I cycled the ignition switch. So Im either getting a code 1 or code 11. In either case, what does this code mean?? I cant find any straight forward answers in regard to this code and basically, what needs to be done to get the ABS to work again??
I really appreciate any replies to this!!
Brian
92 Accord EX KA5MT Sedan
I just jumpered the connection on the pass side for the diagnosis of why my ABS light comes on 10-20 sec after I start driving. The ABS light came on for like 2 sec, then went out, then flashed once, pause, flash once, pause then flashed once again, then didnt light back up until I cycled the ignition switch. So Im either getting a code 1 or code 11. In either case, what does this code mean?? I cant find any straight forward answers in regard to this code and basically, what needs to be done to get the ABS to work again??I really appreciate any replies to this!!
Brian
I will definitely do that. I also read another post on here where u actually jumper the ABS motor and let it run for no more than 10 sec. I did this and the motor kicked in and it made a "humming" noise. Is this normal?
I did put a new modulator/accumulator (the whole assembly with that reservoir thing) in from a junkyard and it was bled the best we could do but i assume u have to use that special honda tool to do it correctly?
There's a pressure switch to shut off the motor without over-pressurizing the system. I worry that jumpering directly to the motor might run the pressure up too high?
Look for a post in DIY about bleeding the ABS.
Modulator pump is a reciprocating piston type and noise is more of a buzz than a hum. If just a hum, the motor may not be able to drive the pump.
Junk yard modulators are cheap, but sometimes you get a bad one. I've had that experience.
93Accord2.2
Nov 7, 2013 07:10 AM
Custnam
Oct 28, 2012 12:50 PM
