92 Accord CEL Code 6, Hard Start
Old Dec 14, 2011 | 11:37 AM
trailshredder's Avatar
Default 92 Accord CEL Code 6, Hard Start
My 92 accord blew the heater hose that goes from the head to the heater control valve last week. I replaced the hose and broke the coolant temp sensor under the distributor and the control valve in the process. Replaced both of those too, filled with coolant and bled the air out. Now, when the car is cold, it is very hard starting. Once it does start, it runs fine but throws a code 6 and the D4 light continuously flashes. I have bled it a few more times but still the same issue. Code 6 is a coolant temp sensor but not sure which one, the one I replaced or the one on the inlet side? Thoughts?
Old Dec 14, 2011 | 03:47 PM
Code 6 refers to the ECT sensor under the distributor. In this link, near the middle of the link, there is an image showing the TW sensor (which is the ECT sensor). Make sure the connector and wiring is okay too.
Overheating Troubleshoot for Honda's Cooling System
Old Dec 15, 2011 | 06:48 AM
I know code 6 means ECT sensor but like I said, I replaced that sensor when I broke it changing the heater hose. Maybe I got a bad sensor?
Old Dec 15, 2011 | 08:44 PM
Check the wires, when you broke it you could have damaged the wire(s).
Old Dec 19, 2011 | 01:10 PM
good call poorman, it was wires going to the ect sensor that got damaged and was shorting out.
Old Dec 19, 2011 | 06:27 PM
you got it, that is the important thing. Thanks for the follow up....I personally like to know how things end up.
Khai Son
Mar 14, 2012 11:32 PM
tingjunkie
Sep 17, 2010 06:37 PM
Stener75
Jul 25, 2010 08:21 PM
valerie
May 15, 2010 08:33 PM
drfrankencopter
Oct 28, 2007 08:36 PM
