92 accord, difficult to start when cold
Old May 2, 2012 | 06:51 PM
  #21
crispin's Avatar
Originally Posted by XxBladesxX
any recommendations for where to go? a while ago I was refered to car-part.com are they good?
I checked between the wires... I thought the other wire was ground?!?!
yes if you check between them both and had 5+ volts then that means the ground wire is working correctly.
the book says to first test between the power wire (red/white) and ground then check each wire together.
But actually as long as you see +5 volts between the two that would mean both wires are not broken and working correctly.
I would check ebay for ecu.
Pull yours out and get the code off it and search by that code.
Old May 2, 2012 | 06:53 PM
  #22
crispin's Avatar
also a question for those on the forum that know more about the 4th gens, since the 4th gen used the f22 and was OBD1 isn't the ECU from a 95 the same?
I have a 95 ECU here that you could have for $25 shipped.
Old May 2, 2012 | 07:02 PM
  #23
XxBladesxX's Avatar
Originally Posted by crispin
also a question for those on the forum that know more about the 4th gens, since the 4th gen used the f22 and was OBD1 isn't the ECU from a 95 the same?...
what are the numbers?
Old May 2, 2012 | 07:07 PM
  #24
crispin's Avatar
37820-poj
Old May 2, 2012 | 07:09 PM
  #25
crispin's Avatar
IGNORE THAT - i SOLD THE 95 ecu ALREADY.
That one is OBD2 from a 97 accord
Old May 2, 2012 | 07:38 PM
  #26
XxBladesxX's Avatar
tease...haha... so where would you recommend (other then ebay)
Old May 2, 2012 | 07:43 PM
  #27
crispin's Avatar
Do you have a pick n pull near you?
Old May 2, 2012 | 07:44 PM
  #28
XxBladesxX's Avatar
ya, I was gonna call them tomorrow, but their are usually picked clean of anything good...lol
Old May 2, 2012 | 08:12 PM
  #29
XxBladesxX's Avatar
ok I just pulled my ecu # it's 37820-pt3-l04 aperantly this car was ment for CA...I'm in WA, does it really matter that I replace it with the exact same one?
Old May 2, 2012 | 08:24 PM
  #30
crispin's Avatar
I am going to say that any non-vtec 90-93 ECU will work fine.
