92 accord f22a4
Old Nov 26, 2011 | 12:23 PM
Or wait, is the wire a WHT with Green stripe? Is there a switch on the upper hose housing, if so what wire(s) are connected to it.
Old Nov 26, 2011 | 12:38 PM
O2 sensor has 4 wires; Wht (signal), grn/wht (ground), Org/blk (heater) and Yel/blk (heater).
Someone may have installed an exhaust header w/o an O2 sensor fitting. Fitting is under exhaust manifold heat shield I believe.
Old Nov 26, 2011 | 07:12 PM
mikepolo's Avatar
two black wires, a green and a white. there is no header cover either and i've looked for an o2 sensor and there is not one anywhere on the exhaust. now i'm pretty sure that this is not the original engine to this car meaning the wires went to the o2 sensor which is located on the header. this header however does not have an o2 sensor on it. i was also told that sometimes the o2 sensors are located elsewhere and maybe it does not need to be connected, but the engine light is on and if it's a problem then it won't pass inspection. also the front drivers side wheel is not centered and looks like it is pushed back a little towards the door. any advice would be helpful, thanks..
Old Nov 27, 2011 | 05:32 AM
A good muffler shop can cut hole and weld an O2 bung to exhaust manifold.
A universal 4-wire O2 sensor would splice to loose wires and you're good to go.
Can't help w/ wheel. Possible frame damage?
Old Nov 27, 2011 | 05:38 PM
mikepolo's Avatar
ok. found the o2 sensor which was located by the cat, but on top of the exhaust pointing towards the motor. Added some wire and hooked it back up and the check engine light is gone now. now to find out what is wrong with this wheel.. thanks and i know i was a bit confusing..
shizoma
Apr 9, 2012 12:51 PM
Pondo
Apr 7, 2012 02:19 PM
hmd810
Mar 18, 2009 08:35 AM
eband00
Dec 29, 2008 01:55 PM
Gastongo
Feb 25, 2008 05:03 PM
