92 accord flashing D4
Old Jan 13, 2013 | 01:37 PM
drp92accord's Avatar
Default 92 accord flashing D4
Hello all. This is my first post, I hope that it is in the right forum.
I have a 92 accord with the D4 light flashing. It will crank and drive but it acts like it is stuck in a high gear. I read about shorthing the blue plug behind the passenger side kickplate. When I do that, I get a list of codes. It shows 1, 2, 3, 5, 7, 8, 14.
I don't know what to do from here to get it going. How do I know what to replace or test? Is there a fix that will cover all these codes or will all 7 codes have to be fix individually?
Thanks for your help. David.
Old Jan 13, 2013 | 01:53 PM
Don't know if this had anything to do with it, but forgot to mention that I just had a front tire replaced and alignment done.
Old Jan 13, 2013 | 02:38 PM
A lot of transmission related problems for your generation Accord has to do with the Transmission Control Unit (TCU). Pull the TCU and open it up to look for damage inside on the circuit board, such as burnt resistors and blown capacitors.
Honda Electronic Transmission Problem- Troubleshoot, Inspection, Repair, Replace.
Old Jan 15, 2013 | 06:57 AM
I pulled the TCU last night and looked at it, but I did not see anything that looked bad. What else should I look for or try?
pejaypreston
Feb 28, 2008 12:15 PM
ddold@gkschools.org
Nov 3, 2007 12:51 AM
BlackLizard
Jul 25, 2007 01:27 PM
mbisenius
Sep 12, 2006 11:20 PM
davidk
Sep 16, 2005 01:55 AM
