92 Accord Idles
Old Nov 9, 2008 | 09:22 PM
ledfoot02
Default 92 Accord Idles
I got a 92 accord with 136k miles on it When I start the car cold it seems like it"s got a very high idle almost 2 grand I let it run till it reachs operating Temp Them all so a sudden it starts to surge from 1500 to 2000 RPMS and when I put it in gear it's at 1400rpm ,That is too high There is no Check engine light can someone lead me in the right direction of where to look.
Thanks
Eddie
Old Nov 9, 2008 | 09:50 PM
cjdm98's Avatar
Default RE: 92 Accord Idles
IACV... Located on the back side of the tb. It is dirty and needs to be either cleaned or replaced.
Old Nov 9, 2008 | 10:56 PM
hondadude's Avatar
Be sure the coolant is full and block burped thru the 12mm bleed screw at the T-stat housing.
Then remove the top off he FITV Fast idle Thermal Valve; 2 phillips screws.
Inside you will see a nylon split screw with a brass cone sticking up thru the center; Turn the screw down a few turns.
When the engine is warm...[temp starting to show on the gauge], you SHOULDNOT hear air bypassing in the FITV.
you can check out hondaautomotive parts. com to find locations of parts
spsweet
Feb 26, 2010 02:34 AM
Accord Pete
Jan 31, 2010 02:50 PM
GsXrCobraMuscle
Jun 21, 2009 09:25 PM
achilles600
Jun 18, 2009 10:13 AM
Jahsaccordcoupe
Nov 16, 2007 06:04 PM
