92 ACCORD AT TRANS PROBLEM
Old Jan 6, 2007 | 04:18 PM
BLAS0827
Default 92 ACCORD AT TRANS PROBLEM
MY "S" LIGHT IS ON AND FLASHING ALL THE TIME I JUST REPLACED MY TRANS COMPUTER IT STILL DOING THE SAME THING !!!HELP!!!
Old Jan 6, 2007 | 08:35 PM
hondadude's Avatar
Default RE: 92 ACCORD AT TRANS PROBLEM
Use this link below, to jumper the Service Connector, then you should get a 'flash' code from the 'S' light .
http://members.troublecodes.net/hond...ice%20conn.jpg
Old Jan 8, 2007 | 09:41 AM
BLAS0827
i just checked the code the s light blinked 9 time what code is that
Old Jan 8, 2007 | 04:52 PM
hondadude's Avatar
Hmm Code 9; The diagnostic chart says the trans should be shifting but not getting lock up
Hope this helps
[IMG]local://upfiles/5417/A05637840C0D4D9098E36C3D23B81DC7.gif[/IMG]
Old Jan 8, 2007 | 09:24 PM
drummer1279's Avatar
ok im going to ask a really dumb question. how does the thermostat aid in torque converter lockup?
Old Jan 8, 2007 | 09:40 PM
hondadude's Avatar
"how does the thermostat aid in torque converter lockup? "
There is a com line between the Trans control unit and the Engine Control unit;
So the TCU dials up the ECU and asks "whats the temp?"
So if the ECU says "BRRRR it's cold" the TCU says "we ain't up shifting till we get some heat".
Threadjacker LOL
Old Jan 8, 2007 | 10:19 PM
BLAS0827
ok well i took the center console off inspected the shifter wires no sign of shorting....when i checked for the coded the s light blinked 9 time is there a on blink first then the code flashes
Old Jan 8, 2007 | 10:21 PM
BLAS0827
and i checked the harness that plug in to tcu no corrosion
Old Jan 8, 2007 | 10:23 PM
BLAS0827
hondadude i can't see the attachment you gave me
Old Jan 8, 2007 | 10:47 PM
hondadude's Avatar
ORIGINAL: BLAS0827
You should be able to click on the thumbnail image or right click it and "save targetas "
