'92 EX 2dr Rear Defrost does not work
The button does not light up when pushed. I've looked, there are no obvious defects in the heater lines. But I don't know if it is the crappy tint causing it either. Any suggestions?
If there is no power to the button, check for a blown fuse. Congrats on 300K miles, I'm at 225K on my 1993 LX...
1 Attachment(s)
I would check for a blown fuse first. But, if the fuse is okay, I would suspect the rear defogger relay or the switch itself. See attached image for location of relay in your underdash fuse/relay box. I've seen where it turned out to be the relay.
You can test the relay and switch. There should be a service manual link in the DIY in this forum. |
It turns out it was the fuse causing the problem. Thanks guys!
| All times are GMT -5. The time now is 04:11 AM. |
