'92 EX 2dr Rear Defrost does not work
Old Jul 14, 2011 | 04:01 AM
Jonah805's Avatar
Default '92 EX 2dr Rear Defrost does not work
The button does not light up when pushed. I've looked, there are no obvious defects in the heater lines. But I don't know if it is the crappy tint causing it either. Any suggestions?
Old Jul 14, 2011 | 09:46 AM
bigpat's Avatar
Almost A Senior Member
If there is no power to the button, check for a blown fuse. Congrats on 300K miles, I'm at 225K on my 1993 LX...
Old Jul 14, 2011 | 11:56 AM
I would check for a blown fuse first. But, if the fuse is okay, I would suspect the rear defogger relay or the switch itself. See attached image for location of relay in your underdash fuse/relay box. I've seen where it turned out to be the relay.
You can test the relay and switch. There should be a service manual link in the DIY in this forum.
Attached Thumbnails '92 EX 2dr Rear Defrost does not work-underdash-fuse-relay-box.jpg
Old Jul 26, 2011 | 06:08 PM
Jonah805's Avatar
It turns out it was the fuse causing the problem. Thanks guys!
Spetsnaz2.0
Oct 19, 2019 09:16 AM
Joslinm
Oct 25, 2013 10:43 AM
rockhoundrob
Feb 6, 2013 06:30 PM
Jonah805
Sep 7, 2011 06:03 PM
