91 accord lx wont start
Old Jul 26, 2011 | 05:02 PM
ballzjonson's Avatar
Default 91 accord lx wont start
it snowed one day here in wa. i went out and started my car like i always do it started fine the next day i went to start it and all it does is turn over also it makes no weird sounds as it turns over but it does turn over any help would be great thanks
Old Jul 26, 2011 | 06:56 PM
For no-start condition, start with following diagnostics:
1) Turn keyswitch to On and note whether Check Engine and Alt lights come on.
If they don't, the ignition switch assy has failed and will require replacement.
2) Turn keyswitch on On, and listen for 2 soft clicks from under the dash, and fuel pump in rear to come on and run for 2-3 secs, and go off. Check Engine light should go off at same time.
If you don't hear the clicks and fuel pump, the Main Fuel Relay has likely failed.
Good Luck
Old Jul 26, 2011 | 07:03 PM
thanks for the tips gonna go try here in a minute
Tony1M
Nov 6, 2023 08:29 PM
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
MrGmo
Sep 28, 2007 01:40 AM
booter
May 11, 2005 02:26 AM
