Sponsored by:
Sponsored by:
92 Honda accord! Help please!!!
Old 09-17-2012, 03:39 PM
Flawless808's Avatar
Default 92 Honda accord! Help please!!!
Hi I was wondering if n e one could tell me what would be wrong with my car. One day I had to fix my brakes due to it was metal to metal. After changing it, later that night I notice that as I was pushing on the gas to accelerate my car started bogging and started to go slow. At some points I thought I was gonna die out. Ive been going every where to see Wat could be wrong. With people telling me different things I didn't know what to think. So I have changed my spark plugs, valve cover gasket, distributor, and fuel pump. N still having the same problem, but got worse. It cranks and turn over but wont start. Could someone helP me please. I'm thinking could it be the main relay or a fuse?!?
Old 09-17-2012, 04:08 PM
I moved your thread from the DIY section to the General Tech Help section so you can get some help.
Please do not post in the DIY section, as per the forum rules.
Old 09-17-2012, 06:52 PM
You need to diagnose the problem. Are you missing spark or fuel? Do you have a timing light?
Old 09-17-2012, 07:34 PM
I had diagnostics done and the code came up for fuel. I jus changed my main relay and still. I gottah play wit it I'm order for it to start. Wat else could it be? Body throttle?
Old 09-18-2012, 06:19 PM
Arrow
After changing my main relay it doesn't bog but now is giving me hard time to start. I gottah play wit it in order for it to start. So now I'm thinking I have to put back in my fuel pump that had in before. Cause the one I put in is smaller n ever since I put that one in it gave me a hard time to start. So I'm hoping once I put back in my fuel pump. Problem will be solved. Cause my car doesn't big after changing main relay. Hope someone finds this forum helpful. Thanks for reading
Old 09-18-2012, 06:45 PM
What code did you get?
Old 09-26-2012, 02:59 AM
K do it's still doing the same thing! I bought a brand new fuel pump, put it in, and it still bogs! Wat else would be the problem! Please help, I'm tryna get it back up n running since I only have 8 more weeks before I give birth. Please somebody HELP!!!!!!
Old 09-26-2012, 08:09 AM
What's the code number, because there's more than one that could be described as "fuel". None of them directly point to the main relay as the problem.
Old 09-26-2012, 01:05 PM
The number that came up was 31.
Old 09-26-2012, 07:33 PM
Take that back 43
Quick Reply: 92 Honda accord! Help please!!!
