92 Honda accord promblems
Old Mar 20, 2013 | 02:41 PM
Honda717Pa's Avatar
Default 92 Honda accord promblems
Whats up people.
I have a 92 Honda accord my d4 lights just started blink I pulled codes from it which is coming back tcu code 1 and code 2 what should I do? Should I stop driving the car?
Old Mar 20, 2013 | 06:12 PM
This is an electrical fault in the LockUp solenoids for Solenoid A (1) and Solenoid B (2).
The coincidence of both codes suggest a common failure mode; wires broken by force, connector relased or damaged, or ECU fault.
LockUp solenoids A&B are a linked pair on the front side of transmission about where the dipstick for AT reservoir is located. Check electrical wiring and connectors first for damage or excessive oil/dirt.
Old Mar 21, 2013 | 07:32 AM
Honda717Pa's Avatar
Thanks I will try it tomorrow is it safe to continue to drive like this?
Old Mar 21, 2013 | 06:33 PM
It should be fine. This only affects torque converter lockup.
Old Mar 24, 2013 | 06:05 PM
Honda717Pa's Avatar
thanks a lot it had a bad connection
Honda717Pa
Jul 12, 2012 01:29 AM
