92 honda accord starting issues
Old Mar 24, 2013 | 12:28 PM
tn6fshn's Avatar
Default 92 honda accord starting issues
I have 2 issues that I really need help on:
1- last week the car would not start, wanted to, fired but wouldn't start.
2- Radiator seems to have pressure all the time and is empty everytime i remove the cap. the bottle always has coolant in it
Thanks for anything you can do to assist in my venture
Old Mar 24, 2013 | 12:55 PM
Find out where the coolant is going.
Some autoparts stores have a radiator pressure tester that you rent for free once you return it. Your radiator should hold about 15 psi. If not, try to locate where coolant is leaking from.
The alternative is that you are burning coolant. Do you see white smoke coming out of your exhaust? Both problems could arise from a bad head gasket, but you need to diagnose before assuming that is the problem.
Old Mar 24, 2013 | 02:22 PM
tn6fshn's Avatar
Thanks, I do see some white smoke and the oil looks clean no evidence of moisture. I will do a radiator check
Old Mar 24, 2013 | 03:35 PM
A small leak will sometimes evaporate as fast as it leaks. Using that tester to pressurize it cold will help you find the leak.
(or did you mean white smoke from the tailpipe?)
Old Mar 24, 2013 | 06:59 PM
tn6fshn's Avatar
yes from the tail pipe no place else
Old Mar 24, 2013 | 08:49 PM
OK then a cylinder leakdown test might make more sense than pressure-testing the cooling system.
Old Mar 25, 2013 | 02:26 AM
White smoke from the pipe..NEW POPE
Sorry but I just couldn't help myself there..
Twisted
Feb 17, 2014 05:44 PM
Hondaboy45
Jul 26, 2010 11:17 AM
asommers
Oct 5, 2009 09:57 AM
Slowaccord
Aug 28, 2007 08:38 AM
MRMASON
Oct 3, 2006 07:09 PM
