1996 Honda Accord LX Starting issues
Old Feb 17, 2014 | 04:06 PM
Twisted's Avatar
Exclamation 1996 Honda Accord LX Starting issues
Hi, my 96 LX is having intermittent starting issues, If you turn the key to start it everything comes on as normal but nothing engine wise, I could try to turn the key multiple times ( 2 to 50 + ) like that and suddenly it will start. I also experience this using a remote starter. I have switched the battery out and the cables were/are tight.
any ideas what the root cause may be
Thanks all
Old Feb 17, 2014 | 05:18 PM
Usual problem is worn copper contacts in the starter solenoid. They are repairable if you have soldering irong (100w at least) and enjoy that sort of repair. Most replace the entire starter.
Symptoms are a sharp click from starter solenoid when you turn the keyswitch to Start, but no engine turn-over.
If you're getting absolute silence, problem could be a starter relay (manual trans only) or possibly a ignition keyswitch assy fault, however keyswitch fault usually results in no dash lights when keyswitch is turned/released.
Old Feb 17, 2014 | 05:44 PM
Twisted's Avatar
Thanks for the Reply TexasHonda, I will check into the contacts at the Starter. THanks for the info
bugrad06
Oct 27, 2013 12:33 AM
thehondaguy
Apr 21, 2013 09:19 AM
johnnyp
Nov 20, 2012 12:18 PM
D Vasquez
Sep 1, 2011 10:43 PM
MRMASON
Oct 3, 2006 07:09 PM
