01 accord oil leak 4 cylinder
Old Feb 3, 2014 | 12:59 AM
ocoF23A1's Avatar
Default 01 accord oil leak 4 cylinder
Driving 140 miles round trip and losing a quart of oil a day. It coming off the timing cover side of the engine. replaced the oil pan gasket, that didn't do it. replaced the cam shaft seal, still leaking. Took it apart again I don't think its coming from the under the timing cover. I'm back to the oil pan or the joint where the oil pump bolts to the block. Put dye in the oil but it not obvious to me where the oil is coming from. The oil is concentrated in the back corner of the oil pan on the drivers side near the oil pan joint. Any thoughts?
Old Feb 3, 2014 | 07:39 AM
There is an oring seal under the rear balance shaft cover that is prone to leakage w/ oil draining from bottom of lower timing belt cover. Balance shaft belt must be removed to access.
Be sure to pin rear balance shaft w/ 4" x 6mm or 1/4" bolt w/ alignment and note orientation of rear balance shaft sprocket pointer w/ oil pump cover to allow correct re-installation.
New oring must be purchased from Honda.
Old Feb 3, 2014 | 10:23 AM
Roader's Avatar
The oil pump housing is "U" shaped so oil leaking from any of the seals ends up at the bottom of the U, then the wind pushes it to the back of the oil pan when driving. 1qt/140m is a lot of oil. Does the front balance shaft seal have a retainer? Pic's:
bernardsblog(dot)blogspot(dot)com/2008/09/honda-balance-shaft-seal-pop-out(dot)html
Old Feb 3, 2014 | 11:13 PM
ocoF23A1's Avatar
No the front balance shaft does not have a retainer. The seal is currently in place. I read the blog I order one when I pull the oil pump. Thanks
Old Feb 17, 2014 | 10:39 PM
ocoF23A1's Avatar
I replaced the o ring on the rear balance shaft looks like that did it. Thanks for the help.
Old Feb 18, 2014 | 08:41 AM
thanks for posting the fix. It's amazing how much oil can get out around that oring seal.
robertng1
Nov 11, 2013 05:54 PM
Chris Jameson
Feb 19, 2013 06:39 AM
mamtsberg
May 30, 2010 07:04 AM
STINKA621
Mar 9, 2009 07:53 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
