93 Accord acts like hits rev limiter
Old Mar 30, 2011 | 07:50 PM
I would have the battery/alternator/starter tested at a parts store. Also, disconnect the battery, then clean all ends of both battery cables and reattach.
You can pull the main relay and see if there is any solder joints cracked. Copy and paste the link below into your browser to see where your main fuel relay is located.
techauto.awardspace.com/mainrelaydefine.html
Old Apr 1, 2011 | 07:14 PM
vdub90vw's Avatar
ok, cleaned terminal and posts to battery = same result, no change
system charging as it should
Tried new main relay and still does the same thing.
Any ideas?
Old Apr 1, 2011 | 07:28 PM
I would unplug each injector and measure the resistance using your volt meter across each injector. That 7.2 ohms is too high on each one.
Old Apr 1, 2011 | 07:47 PM
vdub90vw's Avatar
The 7.2 on each is what the shop said, I checked each one and each registered 2.1 to 2.2 ohms.
accord99
Jun 21, 2011 11:08 PM
felpz420
Jun 14, 2011 07:10 PM
Driving me nuts
Dec 1, 2008 07:17 PM
jaeal
May 12, 2007 11:46 AM
dinzer
Oct 18, 2005 10:27 AM
