93 accord DX brake booster swap.
I've recently replaced my brake booster and I'm still experiencing a VERY hard brake pedal. I've bled the brakes and tested the booster by holding down the brake pedal, then turning the engine on. The pedal dropped a bit when the engine turned over.
I've read that the pushrod length to pedal may need adjustment. (Which I did not do) Here's the link where I read this: https://www.hondaaccordforum.com/for...ll-hard-38174/ How can I adjust the pushrod on the master cylinder and/or brake booster? Thanks! |
In the Common DIY Threads at the top of this section there is a link where you can download a manual.
